Crowds Agents replaced by pins and deformed agents
   1669   0   1
I'm using Houdini Apprentice 16.5.323, and doing a simple populate crowds, agents appear like pins (img_1).
I tried doing step by step, using the walk mocap biped 3, and then the populate and simulate, and worked, then I added 2 more characters doing a run and a zombie walk, to the simulation and the result was that some agents were deformed like (img_2).
If I try to do the populate with 2 or 3 baked agent the result is like img_1, with pins replacing agents.
I did the test in my workstation (i7, 16G, Quadro K2000D) and in my laptop (i7, 16G, GTX1060 updated drivers), the above detailed explanation was on the workstation, I did the samen test in my laptop, and the result was always pins instead of agents!
Help please!!
crowd_issue 1.JPG (338.2 KB)
crowd_issue 2.JPG (194.5 KB)
