In houdini 16 i wanted to scale particle according to age using this expression fit01($AGE,.2,.9)in a point node, it worked fine.
then with the same scene in houdini 15 i use exactly the same expression and its not working at all, even a simple expression like $AGE doesn't work, i think i've missed somthing in the syntax,
please anybody help
in my scene the point node issue is in the geo1 node in root tree
thanks
Scale Expression Issue
1598 1 0- bib
- 7 posts
- jeffMc
- 125 posts
how about something like this in a point wrangle instead of using the Point node
@pscale = fit01(@age,.2,.9);
