Exporting Curves from Houdini to Unity
   3961   1   0
I am trying to export curves from Houdini to Unity without success. I tried both FBX and Houdini Engine HDA but none of them display the curve in Unity. I want to generate the curves in Houdini without manually drawing them using the curve tool in Houdini Engine in Unity. My goal is to generate procedural curves and use them as way-point path for a camera.
Have you tried making the curve node as editable? Check out the Curve Decorator HDA for an example. It can be found under Houdini install location/enigne/unity/Assets/OTLs/Samples/
Edited by seelan - Feb. 28, 2018 08:57:21
