Eroding layers - time offsets in for loops
   2321   2   0
I'm trying to erode away geometry by removing layers sequentially. I want the layers to appear terraced like in the attached reference. I was thinking I could copy the geometry multiple times and uniformly reduce it's scale for each copy. From there, I've tried adding a boolean inside a for each node by piece. That does what I need as far as performing the boolean operation on each piece individually, but I need to be able to offset the timing of each layer to get the terraced look. I've added a time offset node in the for each loop, but it does the offset to the animation as a whole instead of per iteration. I imagine I need to multiply the offset value by the iteration number, but not sure how. Wondering if anyone has any suggestions for achieving this? HIP file attached. Thank you!
Brian
booleanLayers.hip (154.6 KB)
https://www.sidefx.com/forum/topic/53471/#post-240925 [www.sidefx.com]
FX Supervisor
Method Studios, NY
This is great, thank you Tomas! Appreciate you taking the time to post that example.
Brian
