remove duplicate lines?
   Views 6479   Replies 3   Subscribers 3
Hi!
I ended up with duplicate lines (after using a polycut) and I would like to delete all the duplicate/double lines. Any way to do that?
assuming you have duplicate primitives that share the same points (otherwise do Fuse first)
- Clean SOP/Fix Overlaps with Delete Overlap Pairs Off
or
- Poly Doctor Primitives/Overlapping
(Clean uses PolyDoctor under the hood)
Edited by tamte - March 7, 2018 18:49:45
Nice!
Thanks a lot!
-Olivier
is there a way to do this in vex?
