sequence of stills seen as a sequence in cop
   2005   2   0
Hello forum
I'm loading automatically a set of images in cop and these images have a the same number in their filename,
Something like xxx_T200_basecolor.png T200 stands for tile 2meters.
On each frame there's a different image but all of them have T200 inside their filename.
Because of this they're seen as a sequence and xxx_T200_basecolor.png is interpreted as frame 200
So is there a separator that would make things more clear for houdini?
Tried the override but it's still a sequence.
Any clue on how to resolve this would be appreciated since i'm stuck for two days on this problem.
Thank you.
how are you loading the images?
Training Lead
www.sidefx.com
In the file browser, turn off “Show Sequences as one entry”. This will put `xxx_T200_basecolor.png` in as-is, without inserting a $F. This will then be interpreted as a Still Image, which exists at every frame.
