dynamic texture from phyton shell
   2543   5   2
hi all magicians,
this command shows me the texture im using on my material for the geometry:
print hou.node(“./mat/clay”).parm(“basecolor_texture”).eval()
i can change to a new texture:
hou.node(“./mat/clay”).parm(“basecolor_texture”).set(“path_to_the_new_texture”)
I would like to create a dynamic texture in the shell by giving a color and write letters and numbers on it, all inside houdini so i can feed this to a neural netowork that has to learn.
up
Why does it have to be done in python shell? Couldnt you just use COPs?
rand_numbered_textures.hipnc (22.1 KB)
Hi Konstantin thank you for your feedback, I see that through COPs i can create a texture as you did and $I does change numbers but what about text and numbers? I can create a material and point to that cop texture which is great.
However Im creating textures generated from phyton code and I would like to call it in Houdini.
num_pictures = 100
save_folder = “/home/directoy/textures/automated_ready/”
extension = “.jpg”
for i in range(num_pictures):
random_y = (np.random.rand(1)- 0.5) * 2
random_x = (np.random.rand(1) - 0.5) * 2
img = generate_images_0(
cylinder_radius=1.2,
cylinder_height=0.8,
cylinder_center=Point3D(3 + random_x, 0.3 + random_y, 0),
code=“011”,
padding=0.1,
num_jets_for_noozle=100,
noozle_cone_angle=Angle(0.01),
resolution=300,
diffusion_length=0.05,
point_ink_density=5
what should be the final result ?
Is it not better to pre generate the images and then
assign them via prim attribute, like:
s@material_override= “{'basecolor_texture':'uvgrid_grey.pic'}”;
or use material overrides to generate this attribute.
You can use a Python Node or Textport to execute your Code,
to regenerate then the textures.
no the idea is to make the texture in real time
