Hi there
I'm quite new to houdini, wanted to learn it for motion design, I'm used to export 16 bit png too after effects with c4d. Is there a way to do it in houdini?
Cheers
Eoin
Best way to export to affects effects
2066 2 1-
- n7oshea
- 3 posts
- Midphase
- 833 posts
You need to create a Mantra render node, and then select the desired format for output which includes PNG.
One of the better tutorials for getting a grasp on Houdini basic workflow is this one:
https://youtu.be/pu_i6jeayLA [youtu.be]
>>Kays
- n7oshea
- 3 posts
