Constraint freezing the simulation ?
   1909   0   1
i am currently working on my final student projet where i make a plane crash with Houdini. I base the workflow of this project around the RIGIDS III tutorial by Steven Knipping. Everything is working fine until i bring in a simple glue constraint, and when the simulation gets activated at a said frame the simulation simply does not happen. It works when i disconnect/disable the constraint.
I already tried to unpack the alembics upon importation with the alembic node but that didnt change anything.
What is weird is that everything was working fine when i used the model given with the course. I haven't really found anything that helped me online, so hopefully one of you can help me with this issue, i would appreciate it A LOT.
I will attach the files down below.
Thank you !
plane_sim.rar (7.1 MB)
