VEX: nested loops doesn't work as espected
   3336   2   1
Hi!
I have a VEX program to connect those yellow points (grouped as “loosepts”) to its closest point in the mesh.
And it cannot be connected to another yellow point “loosepts”, nor to any of those points outside the red circle (“outerpts” point
group).
So, to prevent those situations, I added a simple if() statement inside the for() loop that searches for the closest point.
int pts = npoints(0);
int closestpt = -1;
float mindist = 0.0;
for(int i = 0; i< pts; i++){//run over all pts
    int isouterpts = inpointgroup(0,"outerpts",i);
    int isloosepts = inpointgroup(0,"loosepts",i);
    //filter some points
    if(i == @ptnum || isouterpts==1 || isloosepts==1){
        continue;
        //vars
        vector cP = point(0,"P",i);
        float curdist = distance(@P,cP);
        if(i == 0){//assign mindist
            mindist = curdist;
            closestpt = i;
        else if(curdist < mindist){
            mindist = curdist;
            closestpt = i;
printf("mindist: %f\nclosestpt: %d\n\n", mindist,closestpt);
if(closestpt != -1){
    //connect current point to closestpt
    int newprim = addprim(0,"polyline");
    addvertex(0,newprim, @ptnum);
    addvertex(0,newprim, closestpt);
The problem is that this code never finds a closest point, and never changes the “closestpt” variable, so it never runs the connection algorythm.
What have I done wrong?
The question is also if VEX nested loops and if() statements run in a particular way I'm not aware of
I'm having problem with this kind of code since weeks ago and can't find help
Best regards,
Antônio Souza
if pt 0 is in any of your excluded points then your mindist is never initialised and your closestpt stays -1
so change
    mindist = curdist;
    closestpt = i;
to
if(closestpt == -1){//assign mindist
    mindist = curdist;
    closestpt = i;
also I wouldn't loop through all the points
you can use nearpoint() to get closest point within specified group, so in your case group that doesn't contain loosepts outerpts or current point
so all you need is to run this in PointWrangle that runs on loosepts group
string group = "!loosepts ^outerpts ^" + itoa(@ptnum);
int closestpt = nearpoint(0, group, @P);
Edited by tamte - April 12, 2018 11:23:13
FX Supervisor
Method Studios, NY
Man, this is a superb solution! haha
I learned three things I wish never forget!
I badly forgot nearpoint()! :O
Thanks, Tomas!
Best regards,
Antônio Souza
