Mantra Render Glitch
   2605   2   0
I am rendering out my fluid sim (Foam + Splash) and get this weird glitch with the rendered sequence.
https://youtu.be/JdNfy4NzE8Q [youtu.be]
Can anyone suggest a fix?
Does the foam and splash particles looks fine if you flipbook it? It seems to only happened at a few frames so you might want to check the caches and resim it if it turns out to be the culprit.
The renderfarm was told by SideFX to try turning off EXR post processing by setting vm_image_exr_postprocess (http://www.sidefx.com/docs/houdini/props/mantra.html)
I'm going to try that and see if it fixes the issue…
