Help centering and aligning an axis!
   5674   15   1
My assembly is from CAD so all the parts are in their correct place already. The “move pivot to center” does so based on a bounding box oriented from the scene. What I need to be able to do is select polygons, or points and have the center of the object align and center to the selection.
Please help me do this. I've played with the c-plane, Align handle, Orientation picking. None of them put the axis in the center of a ring of polygons.
I'm lost.
Hope this helps.
Using @P of selected prim.
Could also change wrangle to use intrinsic bounds of selected prim.
similar process also if you want to use points as your reference.
Also, if you want to use the bounds of a selected group of points/prims, also is possible.
Edited by BabaJ - April 25, 2018 17:05:57
Pivot To Desired.hiplc (74.7 KB)
BabaJ
Hope this helps.
Unfortunately, I was not able to open the file.
Pretend the cylinder is a cad file in the place it needs to be. The Axis is at 0,0,0, normally. When I use the center axis command, it centers the axis according to the bounding box. I need a way to center based on some selected elements, whether it is faces, points, etc…
Edited by Graco123 - May 17, 2018 16:44:23
You have to log in to be able to open the hip file.
BabaJ
Not sure I understand. I downloaded the file, but when I go to open it…I get this error.
Thats odd…opens fine for me, and I'm using a different version than back in April when it was made.
Here is another.
Pivot To Desired v1.hiplc (74.8 KB)
BabaJ
Here is another.
I do appreciate your trying to help, unfortunately I'm still struggling to open the file?
Have you tried the Axis Align node in the Gave Development Toolset?
>>Kays
Midphase
I have looked at the toolset in tutorials but it seems that this workflow moves the geometry to the center point. I can't do that. I need the geometry to stay in place. Sometimes there are hundreds of parts assembled into a model that I get from CAD. It would be painful to move all the parts to the center, and then have to re-align them to their proper place.
Out of curiosity…can you open any other hip file from the forum?
BabaJ
I've never had a problem before.
But can you open any other file now from current posts?
The reason I ask is because your solution is in the hip file I posted.
If you can't open it but others can something needs to be done on your end.( Bug report to forum administrator ).
If others can't open my file ( can someone try? ),
then it's on my end and I should look into it.
BabaJ
I just went and downloaded https://www.sidefx.com/forum/topic/55977/ [www.sidefx.com] RdbPackedObjec_Attrib_N.hiplc . It opened fine.
Anyone else having problems opening my hip posted here?
I decided to try at home on my free version. It worked. Well the file opened at least. Not so sure that I understand just how to use it. But its a step in the right direction…
BabaJ
