Uv Flatten Help
   1994   0   0
Hello
Houdini stops working when I try to View the UV View port.
My Workflow
Import FBX with pre existing UV seams > Quick shade > Vertex split > Group Create > Group Transfer > Uv Flatten > Repack
I'm basically following the tutorial as seen here
https://www.sidefx.com/tutorials/uv-flatten-sew-uvs-with-pre-existing-seams [www.sidefx.com]
but i want to say 70% of the time Houdini will crash when i proceed to try to switch to UV view port .
Experiencing how Volatile Houdini is for the past 2 years , I've learned to Output right before I Switch to UV View.
Or If I even suspect it might crash. Output and output often .
Any suggestions are appreciated .
Does Houdini have a “TdrDelay” and “TdrDdiDelay” that is simply set too short by default ?
Houdini FX Version 16.5.439
Platform: Windows 10.0.10586
Operating System: Windows 10 Pro x64
Qt Version: 5.6.1
Number of Cores: 8
Physical Memory: 31.95 GB
Number of Screens: 2
Screen 0: 1920 x 1080 at 0,0
Work Area 0: 1920 x 1080 at 0,0
Screen 1: 1920 x 1080 at -1920,0
Work Area 1: 1920 x 1040 at -1920,0
OpenGL Vendor: NVIDIA Corporation
OpenGL Renderer: GeForce GTX 980 Ti/PCIe/SSE2
OpenGL Version: 4.6.0 NVIDIA 397.31
OpenGL Shading Language: 4.60 NVIDIA
Detected: NVidia Consumer
6144 MB
397.31.0.0
Processor: AMD Ryzen 9 3900X 12-Core Processor / Memory: 65536MB RAM / Card name: NVIDIA GeForce RTX 2070 / Monitor Name: ViewSonic VP3481
