Getting a Geometry File using a Python string
   4182   2   1
Hi everyone!
I'm trying to get a file run some operations and then save a new file using Python to set file paths, but I can't for the life of me get it to work.
Basic Python to build the file path:
name = 'SM_Floor_3x3_01_High'
highStart = 'S:/Jona_Marklund/_P3/Sculpts/'
lowStart = '"S:/Jona_Marklund/_P3/Low/'
highEnd = '.OBJ'
lowEnd = '.fbx'
highName = highStart + name + highEnd
name = name.replace('_High', '')
lowName = lowStart + name + lowEnd
print highName
print lowName
So, I want to push “highName” into file2's Geometry File field and load that file.
And push “lowName” into rop_fbx1's Output File field and be able to Save to Disk.
Would love to get some input on how I could do this.
Best Regards
//Jona
Something like this?
fileNode = hou.node(“../file2”)
fileNode.parm(“file”).set(highName)
You can drag the fbx node into the python to get the path to the node. Hover over parameters to know what they are called behind the scenes.
fbxNode = hou.node(“/rop/rop_fbx1”)
fbxNode.parm(“execute”).pressButton()
Yes!
Thank you Patrick, that worked perfectly!
Learned something new today, even more thanks for that!
Here's the final code snippet should anyone stumble upon this thread in the future.
#Input .obj name
#Path where the .obj is located
#Path where the .fbx is to be saved
lowStart = 'S:/Jona_Marklund/_P3/Low/'
#Extensions
highEnd = '.OBJ'
lowEnd = '.fbx'
#Build the final .obj path
highPath = highStart + name + highEnd
#Remove "_High" to follow the naming convention of the project
#Build the final .fbx path
lowPath = lowStart + name + lowEnd
#Get the input file node for .obj input
fileNode = hou.node("../file2")
#Get the rop_fbx node for .fbx eport
fbxNode = hou.node("../rop_fbx1")
#Set the "file" paramater to final path
fileNode.parm("file").set(highPath)
#Set the "sououtput" paramater to final path
fbxNode.parm("sopoutput").set(lowPath)
#Test strings
#print highName
#print lowName
