linking noise type to iteraion number?
   Views 3134   Replies 2   Subscribers 0
I'd like to switch noise type of a mountain node according to the iteration number of for loop.
Iteration 0 would pick Sinusoid (because it's the first on the list), Iteration 1 would then pick Perlin, and so on.
I thought I could simply link the menu parameter to the int attribute Iteration on the meta node, but it doesn't work.
Any help is appreciated!
Cheers
You could create various mountain nodes and a switch node that switches.
TIP: If you hold shift+ctrl+alt and drag a node to copy it, it will link all parameters. To remove the one parameter that you want different on the copy ctrl+shift plus left mouse button…
thanks Olaf, very practical tip!
