Houdini Engine Indie Assets options
   2510   6   1
How do I turn on “Use LOD Groups” with the Indie version of Houdini-Engine for Unity?
Since there's no GUI I can't access the ASSET OPTIONS that are references in the documentation
http://www.sidefx.com/docs/unity/_meshes.html [www.sidefx.com]
B-System for Houdini [ae43ae43.gumroad.com]: instance editor, blender like interface.
smuseus
You should have a GUI that looks like this in Indie. I use Indie at home and I get a GUI, unless your referring to something else? LOD Groups were added to Houdini Engine after 16.5.477. I hope this helps!
Glen
Edited by aig_vr - June 4, 2018 08:53:48
Note that by default UseLODGroups is true so you don't need to do anything to turn it on.
Now if you want to manipulate it, without a GUI, you can still access the LOD group setting via the UseLODGroup property on the HEU_HoudiniAsset class.
asset.UseLODGroups = true;
asset.RequestCook(false, false, true, true);
Take a look at HoudiniEngineUnity/Scripts/Examples/HEU_ScriptParameterExample.cs to see how to get the HEU_HoudiniAsset from the root asset's gameobject, set parameters, and request a cook.
I'm on linux, might this be the problem? Just updated to the latest Unity build, and still I can't see the interface @aig_vr posted. I've attached a print of what I see.
This is my installation info:
Required Houdini Version: 16.5.485
Required Houdini Engine Version: 3.1.13
Installed Houdini Version: 16.5.485
Installed Houdini Engine Version: 3.1.13
Houdini Binaries Path: /opt/hfs16.5.485/dsolib/libHARC.so
Houdini RPC Server Executable: /opt/hfs16.5.485/bin/HARS
Houdini RPC Server Process ID: 19743
Houdini RPC Client Module: /opt/hfs16.5.485/dsolib/libHARC.so
Houdini RPC Pipe Name:
License Type Acquired: None
PATH Variable:
/opt/hfs16.5.485/bin:
Screenshot from 2018-06-04 20-21-21.png (28.1 KB)
Yes that would be the problem. The new plugin (and UI) hasn't been released for the Linux builds yet. Should be coming shortly.
Cool, looking forward!
Plugin now available on Linux as of Houdini version 16.5.498. See installation instructions: https://www.sidefx.com/docs/unity/_getting_started.html#GettingStarted_Install_Folder [www.sidefx.com]
