Hi there
Is there a way to select only the newly created edges from a knife modeling operation?
NB
edges from knife tool
3006 2 0- lor
- 292 posts
- davidderwin
- 23 posts
One way to do this would be:
1. make a group of all points
2. do knife operation
3. do a group combine set to group type “Points” to make a new point group, set to “Equals All But” the point group prior to knife (from step 1) (this will give you a point group with only the new points created from the knife operation).
4. do a group promote from points to edges on the group from step 3 (making sure to turn ON the toggle to “Include Only Elements Entirely Contained in Original Group”).
This will give you an edge group with just the newly created edge from the knife.
If you have a lot of knife operations and need separate groups for each new knife edge this might not be the most elegant solution but you can repeat the process as many times as needed or can insert as many knife operations after step 2 and get a single edge group from all knife operations.
- lor
- 292 posts
