Out of memory
   4211   6   3
Hi all!
I am having issues reguarding huge scenes!
I have huge network trees with lots of geometries and particles, and when i try to cache all of these, i get an error, saying out of memory and programs fails, so i can't really cache anything, course of that.
I've heard there are some ways around that, but i am kinda newbie.
Would love to hear from ya!
Thanks for your help!
How do you try to cache it?
If you use a cache sop which caches to memory there will be a problem, try rendering particle simulation to disk as geometry with “rop output driver” SOP, Its a common bullet proof way. Also if you are on windows you are likely to have all sorts of memory problem. There are guys working with big scenes on windows here though .
peliosis
Are you using paging in Windows, your scene uses more memory than your installed RAM?
If you are using paging in Windows vry often maybe is a system inestability, i remember several scenes in Maya I have worked on that are imposssible to use in Windows (it was the 2000 version), so it was the first reason we moved from Windows to Linux.
But I don't know if this is same siytuation as yours.
Un saludo
Best Regards
Pablo Giménez
Yeah i will try to ROP it and see if that helps.
I would love to be on linux, but i can't course of many programs that i use on Windows Xp, unfortunatly.
I've heard it rocks on Linux.
Thanks i will check that!
You can setup dual boot with Linux.
I used Linux for couple years, i know it rocks with 3D apps, but just don't feel comfortable working in it.
xcomb
New distributions like Ubuntu are very user friendly, maybe now it will be more satisfactory for you.
Un saludo
Best Regards
Pablo Giménez
