Grids with rounded corners?
   6281   3   1
I'm sure I will kick myself once figured out but puzzled how to simply get rounded edges on a grid.
Polybevel doesn't seem to work. I'm using the grid in a Sweep SOP.
Anyone?
Hi, polybevel should work using points on the corners. I've attached hip file, is this what you mean?
Rob
Bevel_Grid.hiplc (109.2 KB)
I'm fairly certain that is exactly what Artemis meant, thank you Rob!
thanks a lot!
