Hey everyone!
I have an RBD simulation with packed primitives. I'd like to use some drag force on the spin to reduce rotation of some of the smaller elements. If I understand correctly I'm supposed to use the POP version of the drag spin force. I tried plugging into different inputs of the rbd solver, but it does something really weird. The whole simulation just explodes or pieces disappear.
Am I just plugging it into the wrong place? How is it supposed to be used? Or is it just a bug?
Thanks for any help!
Pop Drag Spin explodes the simulation
3936 5 0-
- paulprk
- 7 posts
- tamte
- 9129 posts
- jsmack
- 8127 posts
- tamte
- 9129 posts
jsmacktamte
I have the same experience, feels like a big to me
as an alternative you can just multiply down angular velocity like
v@w *= .98;
Or something like that, the same for v if drag explodes for you as well
What's the math for samplerate-invariant decay?
v@w *= pow(0.98, @TimeInc);
Where ,98 factor becomes per second not timestep as previously so you'd have to decrease it a bit, but it's all about tweaking
As if you want proper drag it'd be proportional to squared relative w or v, etc
- paulprk
- 7 posts
tamte
v@w *= .98;
Hey! Thanks for the answer. Maybe I'm wrong, but isn't pop spin drag doing something a little more elegant?
Where should I be placing this wrangle? mix rbd solver and sop solver with multisolver and make thew wrangle inside the sop solver?
Edited by paulprk - Aug. 12, 2018 08:12:35
- tamte
- 9129 posts
paulprkwell, if it worked then yes
and while yes, you can work out math from a proper angular drag equation as discussed above, you can as well start simple
just do multisolver with Bullet and Geometry Wrangle:
float d = 0.5;
v@w *= pow(d, @TimeInc);
v@v *= pow(d, @TimeInc);
and see what value works for you, or vary the numbers for linear and angular, but again, nothing is stopping you from doing more involved math using quadratic drag force if you need, or as well submit a bug, the more the better
