Houdini 16.5 crashing when I use TAB menu
   3610   8   1
Is anyone else having an issue where the TAB menu is causing Houdini to crash? This is a new issue for me and my copy was working fine until a couple of days ago.
I'm seeing weird behaviour when I scroll through the menu items as well, like a quick glitch in the menu before it opens out.
When it crashes I get this message “2812: Fatal error: Segmentation fault”
Attached is a crash log and image of the menu glitch.
Would be great to hear if someone else has any thoughts?
Edited by dickonknowles - Aug. 16, 2018 08:02:41
crash.untitled.Dickon's_Laptop_1968_log.txt (1.2 KB)
menu glitch.jpg (91.4 KB)
I have the same problem. I just bought a new laptop, and I only installed Houdini on it. It keeps on crashing when I hit Tab. I have no idea what to do. Is it my laptop's fault? Should I get a new laptop or reinstall?
How to log bugs:
https://www.sidefx.com/forum/topic/15603/ [www.sidefx.com]
System Requirements for Houdini
https://www.sidefx.com/Support/system-requirements/ [www.sidefx.com]
Chris McSpurren
I have the same issue running Windows 10 on my MSI GS73 laptop on 16.5.571. Any version 16 or above crashes. 15.5 works fine.
I actually reported this problem to Sidefx and they gave me a solution. Just wanted to update so people who stumblr upon this thread can have some hope. I updated all my drivers to the latest and it didn't really help but I uninstalled and re-installed to QT4 version instead of the latest. It started working smoothly. So there you go. Try QT4 if it doesn't work for you on production build.
I'm getting the same issue. @hyunj16 i installed the QT4 version but no such luck.
Does this problem still exist for others?
-c
Did you try installing the latest driver of your gpu?
Unfortunately, yes. no such luck.
i have V.399.24 on a gtx 1080
I have Alienware R5 with GTX 1080 too. =T I'll keep searching for a solution. Have you tried reaching out to Sidefx.com? In the meanwhile, you can contact them about the issue. What they will ask you is to save out a file generated from Houdini and send it to them. (Help -> About Houdini -> click on “Show Details”. Click the "save” button at the bottom)
