I've got a problem with houdini. It was working fine until I installed an internet connection to my workstation via a router.
The output of the diagnostics in license server is:
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Thu Feb 20 21:22:46 2003
Local host name: mivcomp
Local server code: 669b22e5
Local ip address: 192.168.0.2
License server name: mivcomp
License server server code: 669b22e5
Server ip address: 192.168.0.2
License server is running: Yes
Has SERVER license: Yes
License server version: 5.5.151
May modify server from this machine: Yes
License Administrator version: 5.5.151
Http proxy host: proxy.arnhem.chello.nl
Http proxy port: 8080
Using standalong mode: No
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
bd6d7d3f Generic Houdini-Master-NonCommercial 5.5 0/0 19-feb-2003
=== For some reason, this license is not valid ===
=== (Maybe machine names don't match?) ===
650e8638 Generic Houdini-Master-NonCommercial 5.5 0/0 25-mar-2003
b0d5c5b5 Generic Render-NonCommercial 5.5 0/0 19-feb-2003
1e77c281 Generic Render-NonCommercial 5.5 0/0 25-mar-2003
sesictrl -i output:
—– SERVER mivcomp ——–
Lic bd6d7d3f: 0 “Houdini-Master-NonCommercial 5.5” Generic 19-feb-2003 +.+.+.+
Lic 650e8638: 0 “Houdini-Master-NonCommercial 5.5” Generic 25-mar-2003 +.+.+.+
Lic b0d5c5b5: 0 “Render-NonCommercial 5.5” Generic 19-feb-2003 +.+.+.+
Lic 1e77c281: 0 “Render-NonCommercial 5.5” Generic 25-mar-2003 +.+.+.+
hserver -l output:
Hostname: mivcomp
Uptime: 0:05:49
License Server: mivcomp
Server Version: sesinetd5.5.151
Version: Houdini5.5.151
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
317 of 511 Mb available
CPU Usage: 11% load
0 active tasks (1 slots)
licenses file:
## Side Effects Software License File
# For license information, please contact:
# Side Effects Software Inc.
# 477 Richmond St. West, Suite 1001
# Toronto, Ontario, Canada
# M5V 3E7
# licensemanager@sidefx.com
# http://www.sidefx.com [sidefx.com]
# NOTE: This file may be modified by the licensee
# Key installed 12:53:03 02/01/03
SERVER beun 669b22e5 cf7954cd11144eb32216649020c886b38c0d60bb8f93
# Key installed 12:53:05 02/01/03
LICENSE Generic Houdini-Master-NonCommercial 5.5 1 19-feb-2003 +.+.+.+ beun \
bd6d7d3f 4883490bde60b1afc6d4e326c2d6ca1b82f903c207eb6
# Key installed 12:53:07 02/01/03
LICENSE Generic Render-NonCommercial 5.5 1 19-feb-2003 +.+.+.+ beun \
b0d5c5b5 e6d77199aa53b9b14ccfea961466337da6c588947bfa
# Key installed 21:14:09 02/20/03
LICENSE Generic Render-NonCommercial 5.5 1 25-mar-2003 +.+.+.+ mivcomp \
1e77c281 a0044d200a7b290f8f4f34eab3efd39d1df83c9589477
# Key installed 21:14:11 02/20/03
LICENSE Generic Houdini-Master-NonCommercial 5.5 1 25-mar-2003 +.+.+.+ \
mivcomp 650e8638 ccc54fbb9ba9def5cf911a0e5ebf066728ba2ea498675
It says that machine names don't match, I guess it takes the name of my router to the internet and gets it license using that name. Is there a way to use the local (workstation) name in this process?
Thanks for all help.
Licence problem
3972 1 1- alife513
- 4 posts
- stevenong
- 1634 posts
Please go to this link [license.sidefx.com] with your host name & server code to get a Houdini license.
After the keys are generated, please manually install only the SERVER mivcomp… string with the Houdini License Administrator.
I hope the above helps!
Cheers!
steven
Cheers!
steven
