As the new amd card is out (https://www.amd.com/en/products/professional-graphics/radeon-pro-duo-polaris)it would be very interesting to hear if voxelsims use both gpus then and if they share the memory. this card has 32 gig ram, that would be amazing for sims, but I have no idea how they behave in sims. is the memory split and by this reducing the sise of the containers that can be solved, are they working on the same voxel container and is houdini able to use the two gpus on one sim at all.
I would prefer a nvidia solution as they have superior dirvers, but they suck when it comes to ram, come on 11 gig!!! I hope there will be a titan version with much more ram. the quadro cards are way to expensive. the titans where perfect at there time.
Do pyro sims benefit from Dual GPU- Cards ?
5974 12 2- sanostol
- 577 posts
- mandrake0
- 645 posts
- BabaJ
- 2137 posts
- sanostol
- 577 posts
mh, interestings points, but not exactly what I asked for
my experience with the nvidia gpus is quite good, drivers are stable and houdini works very well with them, and they still beat any cpu
for the threadripper stuff, some pyro benchmarks would be very helpful, but I expect the 2990wx to drop in performance as half of the cores have no direct memory access, and the other half is slowed down as they have to deliver to the others. and all the render benchmarks I have seen so far do not use large datasets. as soon as You have massive texture access it will drop.
but lets see,it's just a wild guess
- malexander
- 5218 posts
To answer your original question, currently all OpenCL operatins can only target 1 device at a time. So having 2 GPUs doesn't help speed up sims, but it does help if you keep the graphics GPU separate from the Compute GPU. You'll have a lot more memory to work with and the graphics and compute won't swap one another out when VRAM gets tight.
- sanostol
- 577 posts
- tricecold
- 260 posts
How about targeting microsolvers to use separate cards. Would that cause double the vram usage yet faster solves. Can we tag microsolvers for which GPUs to pick.
Edited by tricecold - Nov. 28, 2018 12:22:59
Head of CG @ MPC
CG Supervisor/ Sr. FX TD /
www.timucinozger.com
- animatrix_
- 4741 posts
If you are a CEO FX TD, might be good to pick up one of these:
- kaymanas
- 3 posts
twod
How do we specify the gpu to use?
- Ali Tezel
- 30 posts
kaymanastwod
I am very curious about this as well as I have a dual gpu system on the way.
- Andr
- 899 posts
- anon_user_73180551
- 23 posts
- Enivob
- 2633 posts
If you're running two or more GPUs, run your displays off the lowest powered card, and reserve the one with the most vRAM for OpenCL usage.
Have you tried out the example file at this link?
https://www.sidefx.com/forum/topic/25234/?page=1 [www.sidefx.com]
As I get more confident using the UpRes system, I find myself running more lower resolution sims, leveraging OpenCL for faster feedback. This allows me to tweak the same simulation many more times rather than brute forcing it through hours on the CPU. Once I get the look locked down, I'll upres it to a final VDB sequence, which is CPU driven by default.
Edited by Enivob - April 30, 2020 14:01:32
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
