Add Attrib select channel on OTL
   2064   3   0
I want to add a channel to select attribute like attribtransfert node on my otl (picture 1). But I don't know how load attribute name when we clic on the little arrow like the picture 2. I think I need to use tag maybe but I don't find the solution.
Someone have an idea ?
Thanks a lot in advance,
Edited by Efi - Aug. 27, 2018 19:26:55
Jeremy Gurdal
VFX Artrist
there are node examples already in houdini(ie, smooth sop and attribute delete sop), you can see whats going on by opening edit parameter interface and see the parms with menu item, you will find what you need
Thanks a lot.
opmenu -l attribute1 vtxdel
in Menu script
Jeremy Gurdal
VFX Artrist
names = set()
for input in hou.pwd().inputs():
    geo = input.geometry()
    for attribs in geo.pointAttribs(), geo.vertexAttribs():
        names.update([a.name() for a in attribs if a.dataType() == hou.attribData.Float])
return [x for pair in [(n, n) for n in sorted(names)] for x in pair]
For future reference
Screenshot 2022-11-25 200412.png (420.4 KB)
