Triggering an animated texture map by point attribute
   1798   1   0
Hi everyone,
I wonder if someone can help me on this. I am trying to trigger an animated texture on a plane once a point hits the ground. what would be the best solution to do that?
I have attached an example file here
Trigger_byhit.hip (450.8 KB)
Anim_seq.zip (1010.0 KB)
The attributes to which the texture is connected determines how the texture is used and how it affects the final results. To apply a texture to an object, you map the texture to an attribute on the object's material.
