Hi!
I'm working with 2 photoscanned data of over 4 million polys each. I need to use a transform to scale/rotate/move each one but there's so much lag in the viewport, it's not practical.
I tried the remesh SOP but it takes forever to cook. I also tried the pack SOP but it doesn't seam to help much. Any better ideas?
-Olivier
easy way to transform 4 million poly geos in the viewport?
1344 5 0- olivierth
- 1035 posts
- malexander
- 5193 posts
Switch to Mouse Up mode, at least you'll be able to see the handle move fluidly to about where you want it. Releasing the handle will cook the result so you can see it, then repeat to refine.
Or inport each into their own object, and transform at the object level.
Edited by malexander - Sept. 26, 2018 22:31:07
- olivierth
- 1035 posts
- olivierth
- 1035 posts
- mestela
- 1766 posts
- jsmack
- 7992 posts
