I just finished the new rocket tutorial (from the web) and was gonna render it. But mantra is giving me heck. :?
Rendering from the Output level
-I get a red arrow on the Mantra1 node even though my output path is legit. So what else could be wrong?
-The tutorial has me set my Render Command (Variance, Bucket size and Verbose). But why now can I not edit the Render Command again?
Its grey and I cannot access the + anymore for edits.
-I at one point was able to edit the Render Command (not sure how) and I made it a 2 processor render and removed remote host (since its a local render). It seems like a render was attempted but it seem to crash with every frame started by each processor (I had to kill everything houdini from thre windows task manager). On disk there are files in name only
so mantra named the file and then crashed.
So maybe I'm being stupid-but whats up?
-ral (newbie)
Render a sequence with mantra problems
6025 7 1- ral
- 49 posts
- craig
- 557 posts
- ral
- 49 posts
Beuty-I forgot about that MMB. Thats such a nice tool.
It all came down to the same thing-the script output flags indeed were on.
I'll have to check and see if thats me or if the tutorial scene provided comes with those checked on (if so maybe the scene should be resaved
with them off?!).
-many thanks craig!
ral
with them off?!).
-many thanks craig!
ral
- ral
- 49 posts
- Bernard
- 523 posts
Hello Ral,
I've heard you did the rocket tutorial. Is it possible that, with the VEX Super Material shader, the smoke comming from the rocket looks good, but the smoke from the ground is red colored ?(colored group particles)
For a test I assigned another shader (vex plastic) and that was not red colored.
They don't mentioned this in the online tutorial…
Many thanks,
Many thanks,
- ral
- 49 posts
- Bernard
- 523 posts
- ral
- 49 posts
The red particles in the rocket tutorial is defined by the step ‘Color Code the Groups’ during the create the collisions section. This was for visualization in playback-but I used the ‘bypass flag’ on the ‘color1’ node for rendering.
Since there is a second part to this lesson (not available yet-but I hope soon) which will add a distinct shader to the collide particles-thats what I chose to do for now.
-ral
-ral
