Pop Kill how to set condition to kill particles after certain frames
   9042   5   1
Hi guys
I am struggling with the pop kill node
I want to delete particles after lets say 50 frames
what function or formula do i type inside the vex expression window of the pop kill node?
It seems houdini 16 does not have what the old houdini kill node had to specify this
Thank you
if((@Frame > 50) && (@id % 5 == 0)) { dead = 1; }
BabaJ
Oh my, This forum is full of geniuses
It is working perfectly thank you very much
I had to trim mine as I dont need the @id information
So mine is
if((@Frame > 50)) { dead = 1; }
Thank you
then how to set condition to kill particles after certain age
Correct me if I'm wrong but isn't this just what the life option does in the popnet birth tab? Also can I add what does the % mean in that expression?
Edited by neutrosophic - March 26, 2022 06:34:29
neutrosophic
Hi, neutrosophic, I think the option of typing a formula gives more flexibility in the way you can determine conditions that control the life span of particles. the % sign means houdini will execute a specific task at every specified number of frames, so in other words if I type a formula such as: $F%10==0 it means a specific function will be performed every 10 frames
