Vellum Grains resolution
   2346   3   2
Hi, I'm try to learn Vellum Grains but I do not understand how to control the output mesh/grain resolution.
In the documentation there is no info about this.
TNX for support.
I believe that's controlled by the Vellum Configure Grain node. You can add that to your geometry and then select Create Points from Volume.
TNX man, I've found it!
Is under geo_object > grain_constraints > Grain size, and there is the mass attribuite too.
Grain Size is just a UI sugar that controls the standard pscale attribute behind the scenes. As always, its all about the attributes.
Houdini Indie
Karma/Redshift 3D
