Hi Forum,
I am not sure this is the right place to adress this thing, but it looks like the Vertex Animation Tool is not working in Houdini 17. When trying to bake a textere an error in RENDER_POSITION node stops the process:
Python error: Traceback (most recent call last):
File “”, line 5, in
File “DProgram Files/Side Effects Software/Houdini 17.0.352/houdini/python2.7libs\hou.py”, line 19438, in getPixelByUV
return _hou.CopNode_getPixelByUV(*args, **kwargs)
OperationFailed: The attempted operation failed.
Could not open the COP node
Checked this in a fresh setup as well as in the old projects where I baked without any problems. Can someone please check and confirm that this is not only my PC issue?
7499 13 1- axess21
- 3 posts
- mikelyndon-sesi
- 394 posts
- piranhabytes
- 2 posts
- axess21
- 3 posts
- commedieu
- 31 posts
mikelyndon-sesi
I've just submitted a fix. Some of the parameter names lost their connection when using the HDA in 17.
Mike
Is there any way to fix this on our end for the time being, or should we just stick to 16.5 for now.. How would we know when its fixed?
Thanks.
Edited by commedieu - Oct. 18, 2018 18:28:19
- mikelyndon-sesi
- 394 posts
- commedieu
- 31 posts
mikelyndon-sesi
I fixed it in the 16.5 branch. The latest daily build of the gamedev toolset will have the changes.
Thank you!
You specified 16.5, just to be clear, as of this post, if one wants to export vertex animation, and you have 17 installed, you have to use 16.5/grab the latest daily build of the gamedev toolset — or can you use the 16.5 build and use it for 17?
No big deal, as 17 just rolled out. But just wanted to clear that up.
- HBS-Houdini-User
- 9 posts
Since I had the same question about what I should do with the fix in the 16.5 branch while running 17 I thought I would clarify for anyone else as noobish as me.
I tried updating manually using the 16.5 branch. No joy when running 17 - same error message.
I clicked the Update Toolset game tool icon to auto-update within Houdini. I unchecked production builds and updated to 1.64. Restarted Houdini and… the Vertex Animation Texture tool (now conveniently named VAT just to throw you off the scent) popped up in it's former glory. Haven't done a full test, but at least step one is unblocked now.
Thanks for the fix. Now back to blowin' stuff up.
- HBS-Houdini-User
- 9 posts
The fix allowed the VAT tool to launch, and it writes out what looks to be a good .fbx but then fails with error
Error
Error rendering child: /out/vertex_animation_textures1/RENDER_POSITION1
To weed out my more complex scene as the source of the error, I did a basic pig drop. The .hip file is enclosed
Error
- HBS-Houdini-User
- 9 posts
- commedieu
- 31 posts
- IceBar0n
- 12 posts
Good day to all! I'm making some tests of VA Tool for the first time. I have simple scene of vellum cloth patch dropping onto sphere, doing all steps from the tutorial (Vertex Animation GDC Project Overview) but some things are unclear to me, the annotation in UE4 material says that i must have 5 custom UV channels but i see only 4 annotated uv outputs to connect to main material. What UV input must remain empty ? I suppose it's UV0, but i'm unsure The second question is orientation of the mesh. The cloth patch mesh imported in vertical position ,the animation looks weird. Is is something with the axis i think, but i can't fix it, the convert scene option in import settings has no effect. Can you help me ? Houdini 17.0.387 , toolset v. 1.68
Thanks !
Thanks !
- nicholasralabate
- 114 posts
- GoldenNebula
- 2 posts
Hi! I am new to houdini.
I know this is an old post but I have the same problem than iceBar0n. I am using Houdini 18 with unreal engine 4.25
The script generated by houdini for soft body tells me to have 5 Custom UVs.
And I don't know what gives me this kind of result.
So if anyone has an idea on how I could fix that, it would be SOOOO much appreciated.
Thank you
Thank you
