particle color
   Views 4134   Replies 3   Subscribers 0
I have a particle system, which color my partilces via a ramp function ($LIFE) from blue to red.
If I append a Render POP to these particles, and render out in Spheres, i only get gray spheres.
How can I give these spheres the same color as the particles?
another problem:
I noticed also that render in Discs doesn't work…Lines, Tubes do work.
thanks
Sorry I can only aggree with the above instead of coming with a fix. Even trying to remap the color at the SOP level doesnt work.
On the top of this, if I remove the RenderPOP… it is still rendering my particles as sphere: Both in Houdini 8.0.474 and 8.1.604 on WinXP
See attached .hip
bugRenderPOP.rar (11.2 KB)
Time to get out of this messy world.
It works for me. You need to make sure that you have a Cd shader parameter (ie. a parameter that matches your attribute name). Try using a VEX Layered Surface SHOP. The disc rendering is a known bug.
Thanks Edward, that works great…
Will it be possible to fix the bug of the RenderPOP (discs) ?
thanks,
bern
