Is there an explanation why the top surface of the box has no detailing applied when there's a hole in it? Is this a bug?
Any advice to work around?
Thanks,
.raf
Houdini 17.0 RBDMaterialFracture (Glass) not applying detailing? Is this a bug?
2638 2 3- RafSchoen
- 3 posts
- willp
- 3 posts
- krueger
- 191 posts
Inside the RBD Material Fracture there's a GLASS_FRACTURE node which does the detail. Inside that there's a section for determining the impact surface and the groups aren't working with the boolean. This is from the sticky note:
You can adjust the edgeplanes group and it will work.
Auto determining the impact surface based on the largest area of the geometry. We should let user specify exactly the impact surface in the future.
