Whitewater split foam bubbles spray in H17
   3996   2   0
Hello, this might be a newbie question, but previously in other houdini versions you could easy split foam bubbles and spray via point groups generated by the whitewater solver. However in H17 it doesn't generate these groups anymore. I tried coloring by depth but it doesn't export the Cd attribute for some reason. What's the best method to do it now in H17?
Thank you
On the whitewater solver there is an add state attributes tickbox. This will give you an attribute of 0-1 for bubbles, foam and spray.
how can i split with attribute of 0-1
