Houdini 17: Visualize Voronoi Fracture
   9412   7   4
Hi all,
As soon as I assemble a Voronoi fractured object into packed geometry the wire shading disappears. Both in Flat Wire Shaded as well as in Smooth Wire Shaded I just see a shaded object without a wireframe? When I set the visualisation to either Wireframe of Wireframe Ghost eveything looks fine though.
On top of that, I can't get the Voronoi fractures to be colorized separate anymore (the ‘Visualize Pieces’ option has been removed).
I can't get it to work in the new visualize geometry node.
What am I missing here?
Hey,
yeah i found this confusing at first too (the visualizer not being there)
I think the new workflow is to click on the new visualizer button next to the name prefix, however it just throws errors when i try to use this (i think its broken as it doesnt work anywhere)
I got the pieces to show up by hitting x to add a new visualize node, then setting it to:
- color
- random from attr
- primitive
- selecting ‘name’ from the attr dropdown
And by making sure viewport visualization is on
Hope that helps!
C
I just discovered this issue as well. Most of the “old” options are missing.
What's the new workflow? Thanks, Ambrozie
Edited by Rendering_no - Nov. 30, 2018 03:24:56
Hi, click on the visualizer button works for me. H17.0.382
hi!
- as of H17, if you hit “D” in the viewport, go to Geometry tab, on the right you will see an option “Wire over packed geo”
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
https://vimeo.com/298979142 [vimeo.com]
Just in case someone can't find it in H18, before the scatter point input,
add a node,
- Group Type==> Point(of course)
- Color Type==> Random
and in the voronoiFracture node
- check the
- To Piece Primitives==> ___Cd___
Just push the Pin button.
