How to use "Render" button on custom ROP hda nodes
   3334   3   1
Hi!
I am building some digital assets that pretty much work as wrappers around the geometry, alembic, mantra and arnold ROP nodes.
I need to use customize the “Render” button, by adding a python callback script and potentially some channels. I am not being able to do anything with that button though, as modification seems to be disabled.
How should I go about this? Any suggestions?
you could try this:
I created an object HDA
added a geometry ROP inside
then promoted the 3 buttons to the HDAs top level
now if I open the Type Properties of the HDA I can add callbacks to those buttons
was this what you were trying to do?
rop.hda (25.7 KB)
Training Lead
www.sidefx.com
Actually unfortunately no. The nodes I'm creating must be in the out (ROP) context. When a subnet is created in that context, it automatically creates the “Render” button: that is what I actually need to modify.
Hey, all you need to do is alt middle mouse button click the render button. This will export the button to type properties in your hda.
