Exporting creases with alembic
1406 1 0- anderselmholdt
- 2 posts
Hi. I need to export a model that I have altered in houdini, so it can be rendered in Maya. The model was originally made in maya and contains creases which read nicely in houdini as a vertex attribute (creaseweight) and point attribute (cornerweight). However when I try to export the model back into Maya using alembic the creases do not read properly, and instead shows up in Mayas “extra attributes” section. Does anyone know of a way to get the crease information properly exported?
- houdiniUsers
- 2 posts
You need to enable Render Polygons As Subdivision on the Geometry Node.
Found the explanation in this post:
https://www.sidefx.com/forum/topic/53625/?page=1#post-282561 [www.sidefx.com]
