Interpolating values between points
   Views 2917   Replies 4   Subscribers 0
I need to interpolate values between those points with value greater than 0.
I managed to use the attribute transfer node, which kind of works, but this solution doesn't seem much robust or precise.
I guess I should use the attribute interpolate node, or the vex function primuv(), but don't really understand how to set it up.
I attached the simple project file, any help appreciated.
Cheers
Edited by Andr - Nov. 7, 2018 19:27:31
Q_interpolate_pts.hiplc (163.6 KB)
primuv will interpolate the specified attr of points / vertices on this prim, based on the intrinsic uv of prim.
Attribute Inpterpolate SOP is a integrated SOP that contain primuv function to interpolate specified attrs from source prim.
My English is not good, so I have no ability to explain that what is the intrinsic uv of a prim.
May be there are some topics have talked about it already.
Edited by zengchen - Nov. 8, 2018 01:06:00
attribute_interpolate_by_prim_and_intrinsic_uv.hiplc (170.9 KB)
My Youtube Channel [www.youtube.com]
Hey Zeng Chen thanks a lot, but I could not manage to implement your solution.
I ended up doing this:
1) Cut the curve where the point pscale is different than 0. Each new prim has now a start and end point with pscale > 0. Middle points have pscale = 0
2)For each new primitive, fit01() the intrinsic UV of the middle points to the pscale max and min values of the ends point.
It was a little bit convoluted but seems to work.
Probably there is a better and faster solution that I'm not aware of. Would love to see it
Thanks a lot again!
I attached my solution if you want to critique it.
Edited by Andr - Nov. 8, 2018 05:37:32
Q_interpolate_pts_FIX.hiplc (168.8 KB)
Andr
I may misunderstand your question, sorry about my English, I have misunderstood some questions already…
hey no worries, my question might have been not clear, as I'm not native english speaker as well.
thanks again for caring
cheers!
Edited by Andr - Nov. 8, 2018 07:26:15
