Operator List in 3DSMax
   3869   2   0
Hi. I'm wanting to expose an Operator List in my HDA to 3DSMax so I can add multiple object to an object merge. It works ok in Houdini, but I don't see how to pass any objects into the list in Max.
Dragging objects into the field doesn't do anything. Typing strings into the field including wildcards doesn't do anything either.
Is there a different way to pass a list of multiple objects into an HDA inside Max?
I can add an expanding Operator Path item, but it means adding one object at a time and doesn't show the objects in the interface so I can't see what objects are included. I'd rather pass a multiple object selection at once.
Operator Lists aren't currently supported. There is an existing RFE (#91204) for allowing multiple objects to be merged into one input.
I've seen the expanding Operator Path bug and I will look into that.
Ok thanks.
