how to import a fbx without the fbx window???? (ui to big)
   5278   8   0
how can i import a fbx without the fbx window??? and i ask this because in a small resolutions the window doesnt fit the screen and you cant click the accept button!! and the window isnt resizable, i wonder why they dont make this window resizable, do you know whats the logic behind this?? so the question is how to import a fbx without this window, i cant click accept!!!
Edited by dyei - Nov. 19, 2018 09:59:28
Minimum resolution: 1920 x 1200 (widescreen).
https://www.sidefx.com/Support/system-requirements/ [www.sidefx.com]
so if you are on a Laptop you need an external monitor.
greetings
Olaf
This came up before in another thread. A work around is to reduce the ui scale, try setting it to compact and see if that helps. Another option is to use the fbximport command from the textport.
http://www.sidefx.com/docs/houdini/commands/fbximport.html [www.sidefx.com]
Edit:
or python
http://www.sidefx.com/docs/houdini/hom/hou/hipFile.html#importFBX [www.sidefx.com]
Edited by jsmack - Nov. 19, 2018 11:15:27
Depending on your use case, Agent SOP can also help. It can import an FBX file directly.
Olaf Finkbeiner
greetings
Olaf
jsmack
Edit:
or python
thanks!
NECRO BUMP!
Just experienced this issue. I do have an external monitor, but that is also 1080P. So what I did was instead of extending the monitors left to right, I extended my second monitor BELOW my primary monitor! So now the import button appears at the top of my second monitor.
HTHs!
This is an old issue, but it still happens with this and many other windows. The way I get around it is by grabbing a part of the visible window which let's me resize it and adjust it a tiny bit, then when I let go, the program moves the window to make it fit in screen.
Use the geometry node to import file
