tricky COPs: Crop image by its alpha?
   3633   10   2
I'm trying to figure out a way to get rid of the blue area.
Is there any way I can use the alpha channel (shown on the right) to crop the image? (without leaving COPs. Can't use any SOP trickery )
thanks for any help!
project file attached
Edited by Andr - Nov. 19, 2018 17:01:39
cropbyalpha example.JPG (43.7 KB)
Q_cropByAlpha.hiplc (104.7 KB)
Try dropping down a crop node.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
Unless I miss something it doesn't seem to read the alpha.
I need the crop to happen automatically, without typing in value by hand.
cheers
i do stuff like this in sops
hightfields are quite cool for that. You can iterate quickly over them and find coordinates that are.
trace-sop might also help
Doing in sop should be easy, but my (limited) experience with COPs tells me that it wouldn't be good for efficiency, especially if you deal with multiple high-res images; and it would also add a layer of instability to the system (more prone to crash).
Slightly related:
I need to feed a parameter of a COPs node with a specific pixel value from another node.
Is there any hscript function that I can use in parameter to retrieve the value of a pixel? I can't happen to find it.
I've found only a VEX function in the docs, but I don't really understand how and where to use it:
http://www.sidefx.com/docs/houdini/vex/cop_sample_suite.html [www.sidefx.com]
My convoluted workaround so far: I create a plane with the solid color of the pixel I want to read, export it to SOP and read the Cd attribute from Sop with a point() function. It works, but it's slightly imprecise and very unstable.
Edited by Andr - Nov. 20, 2018 05:09:53
Andr
http://www.sidefx.com/docs/houdini/expressions/pic.html [www.sidefx.com]
or if you need more options
http://www.sidefx.com/docs/houdini/hom/hou/CopNode.html#getPixelByUV [www.sidefx.com]
FX Supervisor
Method Studios, NY
thanks!
tried to find a COP that could be misused to do this, no luck.
really need a wrangle COP with an equivalent to detail (run once)… and writable crop & window sizes.
bbox.hiplc (301.5 KB)
I don't think After Effects can do this either. You can pre-comp something but you must manually set the size of the pre-comp.
I could see it being possible in SOPs using an attribute from map, followed by a delete and a bound.
You could probably do this using ImageMagik and some PHP code too.
Why can't you use SOPs?
Edited by Enivob - Nov. 22, 2018 10:43:28
cpb
that would help to easily store some attributes and recall them.
I've been trying to use the suggested pic() function, but I did something wrong apparently, it seems to be able to read it but Houdini becomes unresponsive in my system. Like it's being sucked into some computation loop. Have to kill Houdini every time.
Do you understand what is broken?
See attached .hip
Edited by Andr - Nov. 22, 2018 11:21:18
Q_COPs_readPixel.hiplc (100.3 KB)
Enivob
This back-and-forth between SOP and COP seems to me an additional step that would slow down the cooking, especially if you want to proceed with multiple highres image. So I tend to avoid when possible.
But that's just based on my limited experience with COPs
