Vortex Force DOP node causing segmentation fault.
   2659   3   1
I am having issues using the Vortex Force node i DOPs. No matter what I do, as soon as I place the node and connect a SOP Geo node to it, it crashed with a segmentation fault. The logs don't show much that I can see. Even using the example file from Houdini help causes a crash.
I even did a complete fresh reinstall of Windows and a Fresh Houdini install and it is still happening. I can't say i've seen this happen with any other nodes.
I know there is issues with the latest Nvidia drivers with OpenCL. Could they have something to do with it?
I've attached the crash log and hipnc file (it's literally a blank file with the SimpleVortex example from help in it.)
crash.untitled.Josh_13208_log.txt (4.8 KB)
crash.untitled.Josh_13208.hipnc (154.1 KB)
I'm experiencing a lot of segmentation faults too since Hou 17.
I was experiencing crashes with 16.5 but not so many and so random.
It seems the latest daily build does not crash. I can't see anything in the changelogs that indicate anything has changed with that node though.
I'm having the exact same issue as Josh Oram described
