copy stamp the L-system rules (turtle randomizing)?
   4881   3   1
Hey there,
This might be a silly question
It looks as if variables (for “Stamping”) from a copy sop can't be used in the “rules” of an L-system.
can they?
I would love to be able to randomize my copies of an l-system on a template geometry on a “turtle/rule” level.
No problem “stamping” things like “generations”.
Doesn't look like it can be done to the “rules” though.
Jim Ellis
Jim Ellis
www.emsh.calarts.edu/~jim
It works, you just have to work around the fact that Copy Stamping with the Copy SOP only supports numbers and not strings.
So you'll need an expression in your rule that looks like this
if (stamp(“../copy1”,“test”,0)<10) {
return “FFFA”;
} else {
return “FFAA”;
Hopefully, one day SESI will add some string coyp stamping parameters to the Copy SOP. (There already is a stamps() expression for string….)
Wolfwood
return “FFFA”;
} else {
return “FFAA”;
Or you could make a variable, or list of variables that contain separated strings, e.g. “F A”, and then
`arg($myVar, stamp(“../copy1”, “test”, 0))`
i.e. use the stamp value as an array index value.
Antoine Durr
Floq FX
antoine@floqfx.com
_________________
Yeah I was afraid that the Copy sop didn't use strings,
but it was funny because I didn't get an error flag in either the “Copy” or the “Lystem”…
and with either of those, you cant just click next to the parameter value and see your input/output data.
But what both you guys suggested works wonderfully!
Thanks so much!
Antoine's seems to be exactly what I'm after…
and sick/amazing things are starting to happen.
Jim Ellis
