Do I have to use VS2015 to build the USD Houdini plugin?
   2080   2   1
Hello there,
I used VS2017 to build the USD houdini plugin and the build itself was successful. But after I set the Houdini environmental variables and launch Houdini 16.5, I got the incompatible compiler versions error and then Houdini crashed. I did some searches and it seemed that Houdini 16.5 is built using VS2015, so do I have to use the same version of Visual Studio to build the USD Houdini plugin? Or is it another issue?
Thanks for any comments and ideas.
Edited by quchen - Nov. 29, 2018 09:07:52
Yes. Use VS2015 for Houdini 16.5. Use VS2017 for Houdini 17.
Ben
Thank you BRog. Yeah I rebuilt the plugin with VS2015 and now it's loaded in Houdini 16.5.
