H17 Autorig's hand catpure problem
   2815   10   2
Hi
I got a problem with the autorig system. It's like a lag in the interpolation and I got ‘popup’ in the skin every 25 frames.
It seems to happen only on the hands.
I try on the production 17.0352 and the last daily build, with a new scene, the tommy guy and the basic autorig and I got the same problem.
Regards.
autorig.mp4 (4.3 MB)
it's hard to say what might be causing this…
can you post you hip here?
Training Lead
www.sidefx.com
Sure.
Like i said, it does not seem to be related to my scene.
So I just replicate the problem in a new scene with H17.0.352
1. Create tommy
2. Create autorig biped
3. Adjust the arm / legs etc (I don't know why it doesnt match the test geometry by default)
4. Generate without errors.
5. Key the hand controller
6. My problem.
autorig_problem.hiplc (13.2 MB)
weird - it looks like the constraints for the fingers are just taking a break on a couple of frames…
I'll look into it
Training Lead
www.sidefx.com
I can see the issue in your file, but I can't reproduce it in H17.0.416 - this is the latest Production Build
can you try building the same asset from a new session in 416?
Training Lead
www.sidefx.com
I downloaded and installed the last available build - H17.0.417
Unfortunately the problem persists on my side
Well if you can't reproduce it, then maybe it s related to some cached data ?
Edit : same problem with production build 416
Edited by psyiox - Nov. 30, 2018 16:19:30
autorig_problem_h417.hiplc (13.3 MB)
I know what the issue is - there was a change made in the way constraints are built right around the same time that these modules were being made, and the autorigs didn't get updated - I'll make the change and replay back here when it's done…
Training Lead
www.sidefx.com
Great !
Thank you
Hi
I seem to have a similar recurring problem with the autorig, after keyframing the hand controls start twitching.
I'm using Houdini 17.0.459
Was the above issue ever resolved?
Many thanks
rig.mp4 (5.1 MB)
just tried it in Houdini 17.0.502
and it seems fine.
Training Lead
www.sidefx.com
Thanks for the reply Michael, it seems to be working for me now.
