does someone know a technique to trace the shilouette from a polygon object facing a specific ortho view?
The outlines are needed as a nurbs/poly curve in sop level.
I tried to flatten the object but ran into issues with fixing the overlapping primitives/ remeshing in an efficient and accurate way.
Hendrik
Trace object outline in ortho view
3716 7 3- hchendrik
- 2 posts
- neil_math_comp
- 1743 posts
It looks like it works to just do: Triangulate 2D, Group unshared edges (making sure to turn off the “Base Group” toggle), Dissolve the edge group with “Delete Non-Selected” for Operation and “Remove Inline Points” off.
- sjc000com
- 4 posts
- Konstantin Magnus
- 686 posts
SideFX Labs has a node for this:
https://www.sidefx.com/docs/houdini/nodes/sop/labs--extract_silhouette-1.0.html [www.sidefx.com]
- animatrix_
- 4729 posts
Here is one way:
Transform into NDC (Point Wrangle):
Ray Intersection (Point Wrangle):
Here is one way:
string cam = chs("cam"); vector p = toNDC(cam, @P); p.z = -1; p = fromNDC ( cam, p ); v@outlineNormal = normalize ( p - @P ); v@pworld = @P; @P = p;
vector n = v@outlineNormal; vector phit = 0; vector uvhit = 0; vector p = v@pworld + v@N * 0.001; int pr = intersect ( 1, p, n*1000, phit, uvhit ); int result = pr != -1; pr = intersect ( 1, p, -n*1000, phit, uvhit ); result |= pr != -1; if ( result ) removepoint ( 0, @ptnum ); @P = v@pworld;
- Konstantin Magnus
- 686 posts
Here is another way:
https://procegen.konstantinmagnus.de/drawing-a-silhouette-around-a-mesh [procegen.konstantinmagnus.de]
- sjc000com
- 4 posts
Thanks every body ,I don't want a silhouette around the object I want to extract a full elevations from my model .
Konstantine I am so glad I found you answer me here cause I thought that you will get my point as an architect ,that's why I've sent you an email about it with the hip file,sorry I don't know that you will respond here so fast.
What I want is something like what is in rhino program which giving 2d lines(curves) from 3d model
- Konstantin Magnus
- 686 posts
This would be a way to create curves for floor plans and elevations from 3d meshes:
https://procegen.konstantinmagnus.de/architecture-floor-plans-and-elevations [procegen.konstantinmagnus.de]
Edited by Konstantin Magnus - Jan. 1, 2023 13:06:23
