cpp error
   3468   2   1
Anybody know anything about this issue?
I get this warning when starting reshift in a specific scene i got here.
Scene renders fine.
But, and its a big but, occasionally when i save i get an error message that it has stepped on pretty much every attribute in the scene and it basically breaks the file where most point attributes that goes to redshift is unrecognized.
cpp error: “<internal>”:252 Mismatched quotation marks
<internal> Error(252): Expecting close brace for script
cpp error: “<internal>”:105 Mismatched quotation marks
<internal> Error(105): Expecting close brace for parm
cpp error: “<internal>”:654 Mismatched quotation marks
<internal> Error(654): Expecting close brace for parm
Here you can see what happens when the scene braks.
Edited by FXdal - Dec. 18, 2018 00:01:33
Found the error, it was caused by using the instancing from packed primitives in redshift, just a bit surprised that it corrupted the file.
Hi, I do have pretty much the same errors here. How did you find out, that the instancing from packed primitives option is causing this? Did you have no further problems after not using this option?
