Extrude Stairs
   3017   4   1
Extrude….but in stair steps rather than linear.
http://www.vusta.com.au/ [www.vusta.com.au]
Edited by vusta - Dec. 18, 2018 18:43:52
That looks cool! is it done with extrude sop on loop or with some vex?
Mohan Pugaz
movfx
I'm not a coder….there is one simple wrangle tho….the extrude SOP is the building block, you can dissect the logic, I haven't hidden anything from prying eyes…..
This is wonderful. Gives me much to depict and learn. Thanks a bunch!
just FYI for those wondering what the heck is going on with the Extrude SOP.
If you dive inside the HDA and examine the extrude in either branch of the for loops, for Distance, you can easily put the cursor in the field then ALT+E to bring up the expression editor, easier to see the code that way. But for Extrusion Mode, to see code, rclick on the field>Expression>Edit Expression…then you can see the code behind it.
