Ocean Wave Tank Rendering
   1830   0   1
Hey there, I'm running into issues when rendering my wave tank with my large ocean….you'll see what I mean in the attached render. I'm not sure if it's not meshing properly or what. Everything seems to be correct as far as I can tell. I've attached my scene file if anyone has time to take a look.
I'm also getting some weird geometry blips going on underneath my fluid surface. I used a delete sop after my particle fluid surface sop to get rid of those problem points…I don't know if that could be messing up my render somehow as well.
Thank you!
Edited by jasonsm - Jan. 15, 2019 11:52:11
ocean_js.zip (904.2 KB)
