how to chop lag base on an attribute per point?
   1419   2   0
I am trying to lag a line, but I want to affect the points base on an a ramp attribute, this is what I have so far.
lag_example.hip (115.3 KB)
What improvement do you want on what you already have? This seems to do what you are describing.
Sean Lewkiw
Machine FX - Cinesite MTL
well if you see the original length of the curve than after the chop is way shorter like the initial geometry changed
I put an example mixing with a vopsop but I wonder how to do all in chops
Edited by pelos - Jan. 17, 2019 02:58:37
lag_example.hip (227.5 KB)
