Hi everyone,
sorry if this is really a stupid thing but i was trying to have an add sop with the same number of points as there are primitives in another sop, now i can't seem to get this to work i try to insert an expression in the number of points field but it doesn't let me type anything there. I tried using ‘alt + e’ and inserted the following:
nprims(“../curves_grp”)
Where curves_grp is a group of curves, but the expression doesn't stick when i get out, if i press ‘alt+e’ again there's no expression there. Is this something i'm doing wrong or there's no support for expressions to define the number of points in Add SOP?
Another thing, i think it would be useful when dealing with expression functions to have some variable to automatically reference the input SOP, something like $INPUT or $PARENT that could be used by any expression even if one changes the node input. Not sure if something like that exists but i think that is probably easy to achieve if it doesn't.
Cheers
expression not working in Add SOP
3618 2 0- strayDog
- 16 posts
- wolfwood
- 4271 posts
strayDog
Hi everyone,
The Add SOP can be a bit tricky. The best solution is to create the points with a Grid or Line SOP, then pipe that into a Add SOP and turn on Delete Geometry but Keep Points. Using the Add SOP to create a bunch of points can be quite slow since Houdini will create a UI dialog for each element.
I agree. Sometimes what I do is create a custom expression like
string in(int inputnum) {
return opinputpath(“.”,inputnum);
Then in my expressions I can just type in something like
point(in(0),$PT,“P”,0)
- strayDog
- 16 posts
Thanks Wolfwood,
I followed your suggestion, i used a line sop instead to create all the points and then simply deleted them with the Add SOP, after all the points positions are being set with a Point SOP anyway so this way i'm able to control the number of points through expressions which is what i was looking for.
About that custom expression, that's a nice tip my friend, i think i'll be using that from now on, nevertheless i believe implementing a variable to reference the input should be something pretty straightforward for such a great development team
Cheers
Cheers
